C 500 PRO
  • copierlady
    • 338
    C 500 PRO
    Working on the beast again! I relaced all the dv's and drums on this unit and i still have some very defined thin white lines running through the copies. They show up full color or single color, all of them.
    Tryed exchanging the transfer belt no luck. Fuser looks good. Any thoughts on this? I am really over this machine.
    "when she's good she's good but when she's bad she's oh so bad!" thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Re: C 500 PRO
    Paul@justmanuals.com
    • laserman06
      Conservative in Exile
      • Dec 2007
      • 323
      Re: C 500 PRO
      Clean all of the slit glasses on the write units.
      Reseat connectors on the image process board.
      Provide pictures of defect if possible.
      The family that prays together, stays together!
      Smile God created you and He doesn't make mistakes!
      Relax, God IS in control!
      Be still and know that I am God
      Ps 46:10
      • Hemlock
        • 432
        Re: C 500 PRO
        Grooves in the fuser maybe?
        “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
        • tech51
          • 846
          Re: C 500 PRO
          Try cleaning under the dev units and the potential sensors. Small (and I mean tiny) pieces of lint from cleaning cloths can lodge there and cause fine white lines because they block the laser path. I've stopped using cleaning cloths on these, I just use a brush and my vac. Hope this helps...
          • RRodgers
            • Jun 2009
            • 1947
            Re: C 500 PRO
            Sometimes you get clumps of toner in the dr blade, just clean them with a business card. Also, as suggested above you'll get junk under the dev unit (usually dev hanging down) be sure to clean those off as well. Hth Gl
            • RRodgers
              • Jun 2009
              • 1947
              Re: C 500 PRO
              Doh! Forgot to mention, dr blades on these are on the BOTTOM of the dev unit. Take the cover off first.
              • copierlady
                • 338
                Re: C 500 PRO THANKS
                Thanks guys lots of suggestions. I know what i'm doing this weekend. Thanks again, i'll let ya know.
                • Hemlock
                  • 432
                  Re: C 500 PRO
                  Run a skyshot of each color individually; are the lines in the same place on each or do they move?
