bizhub 223 user function 2 in 1.. help?
  • brent
    • Nov 2008
    • 1214
    I know this is not a very technical question. but I have the manual and still can't see how to put in the 2 in 1 ( 2 images that are half size onto one sheet) the machine will do them on a regular sheet of paper going the one way. but I need them one on top of the other in the portrait position. hope I explained it and I hope someone has a machine handy that could just take a quick look. thanks
    brent
  • boanda
    • Feb 2011
    • 79
    Re: bizhub 223 user function 2 in 1.. help?
    Select
    1. 2in1
    2. paper
    3.zoom 100%(if original is 2x or more smaller then output paper)
    4.put original on the same place both times
    Im doing like this
    • brent
      • Nov 2008
      • 1214
      all im saying is that the machine will do this. but the machine puts the images reduced side by side. I want them on top of each other. thanks
      brent
      • boanda
        • Feb 2011
        • 79
        brent
        Thats what i get
        • TheOwl
          • Nov 2008
          • 1732
          Under Duplex / Combine, I think that there is a button where you can change the orientation of the N-Up.
          It should automatcally ask you if you select 8-in-1, but not sure about 2-in-1. Have a look for the other button.
          • brent
            • Nov 2008
            • 1214
            ill look again tomorrow. I looked at all the selections. and did not see it. I could have missed it
            thanks
            • boanda
              • Feb 2011
              • 79
              In the top right corner of display when u enter Under Duplex / Combine
