THIS MACHINE IS DISPLAYING THIS MESSAGE....<TONER CARTRIDGE C AND Y MISSING>..wherever we replace the cartridge with new ones.the machine is still showing the same message.but there is a time i change both cartridge and imaging unit (for both cyan and black),the machine worked for 2 hours then it displayed the same message...solution please??
bizhub c35 displays (toner c and y missing)
Re: bizhub c35 displays (toner c and y missing)
are you using new out of the box, genuine toners ?
the cartridges that come with the machines when new do not have new article detection boards attached to them and will not work ever again on any other machine or the same one once the machine has passed the first toner exchange request.Comment
KonMin has an update for the rails but I ran into more of the seals blocking the toner path. Seems they don't get locked into place correctly. Check the window on the IU unit and see if it is full. We normally SHAKE the crap out of the IU to try to recover it. Sometimes it works, sometimes not.Comment
Try these olivetti bulletins, same machine as the KMComment
What a crap.
Any battery operated sex toy is designed better.
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
JPHO
