bizhub c35 displays (toner c and y missing)
  • leuwcharly
    • Sep 2011
    • 9
    THIS MACHINE IS DISPLAYING THIS MESSAGE....<TONER CARTRIDGE C AND Y MISSING>..wherever we replace the cartridge with new ones.the machine is still showing the same message.but there is a time i change both cartridge and imaging unit (for both cyan and black),the machine worked for 2 hours then it displayed the same message...solution please??
  • Kenny
    • Jun 2009
    • 524
    Re: bizhub c35 displays (toner c and y missing)
    Hi i am having the same issue with a magenta toner missing message, did you manage to find a solution to this problem?
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      are you using new out of the box, genuine toners ?
      the cartridges that come with the machines when new do not have new article detection boards attached to them and will not work ever again on any other machine or the same one once the machine has passed the first toner exchange request.
      • Kenny
        • Jun 2009
        • 524
        no new toners, machines have been through a few imagine units and toners with no problems we have 3 or 4 of these machines doing it now ?? Konica very little help
        • mo0651
          • 1054
          KonMin has an update for the rails but I ran into more of the seals blocking the toner path. Seems they don't get locked into place correctly. Check the window on the IU unit and see if it is full. We normally SHAKE the crap out of the IU to try to recover it. Sometimes it works, sometimes not.
          • lanierboy
            • 149
            Try these olivetti bulletins, same machine as the KM
            • Kenny
              • Jun 2009
              • 524
              will check this now Lanierboy many thanks so far !! much appreciated
              • Hansoon
                • Sep 2007
                • 3374
                What a crap.
                Any battery operated sex toy is designed better.
                Hans
                • JPHO
                  What was the fix for this issue? I have one doing the same
                  • bok720
                    • Jul 2019
                    • 2
                    Dear All,
                    I have this issue on 2 machine. May I know anyone have solutions for it?
                    appreciate some help.
