bizhub 350 error 5352
  • yannii33
    • 121
    I replaced the fuser andstill get this code once in a whileand the paper keeps stopping at the transport on the side door are these issues related any fix is appreciated
  • Hansoon
    • Sep 2007
    • 3385
    Re: bizhub 350 error 5352
    That's a failure of the Cooling Fan M5 inside the right side door. First try to clean and:
    From "AllSolutions"
    Description
    C-5352 (C5352) at power up or shortly thereafter.Thefirst copymay feed, but jams.
    Solution
    PROBABLE CAUSES:
    1.Failed PWB-A board.
    Replace the PWB-A board (p/n 4040-0101-03).
    2. Fan failure.M5 is not running or not turningat the correct speed.
    Replace the M5 fan (p/n 9313 1100 33).
    3. The imaging unit contacts are shorted.
    Check the imaging unit contacts and correct as necessary. If the error code persists, replace the imaging unit(p/n 4040 0752 00).
    4. Thepaper stops at or before the timing rollerin the vertical transport section due to poor drum unit to charge corona shell contact.
    Re-form the small copper tab on drum unit that contacts the charge corona shell. The tab is located on the front of machine, andthe end of the drum unit.
    or you might try:
    http://www.copytechnet.com/forums/ko...-di-450-a.html
    Hans
    • kazihaha
      • 100
      Today I fixed this already.
      Just replace the Cooler Fan. ^^ You can contact me at YM! kazihaha
      https://sieuthithietbivanphong.com
