When we send a test print job that has to use the 3 colors to make black text it is not clear. it is like the the 3 laser are slightly off from each other.
i have compleatly cleaned the copier. ran color registration adjustments in 36 mode. anytime i run manual registration adjustment I get and error.
On the manul adjustment print out the colors are not lined up like they should be.
