DI 450 c1440 and 1441 codes
  • nmfaxman
    • 1702
    Memory checks good and not print controller ever installed.
    Have replaced ccd unit and checked connectors to to pwb-IA and all outputs from PS show good.
    Repairing it for church for free so I don't want to put a lot of money into it.
    Anyone have any ideas?
  • Hansoon
    • Sep 2007
    • 3386
    Re: DI 450 c1440 and 1441 codes
    Mirrors knocked out of position and/or dirty? Platen glass sitting right and clean (especially the underside with the white strip)? Any sources of false light entering optics?
    Hans
    • nmfaxman
      • 1702
      Checked mirrors and sensors before I pulled CCD unit.
      Sent ccd to Hytech and they said it was good.
      Pulled and reset all connectors on ccd and pwbIa.
      It was working before it was moved, but I don't see any physical damage.
      • mitchl
        • Apr 2007
        • 501
        Make absolutely sure that one of the mirrors isnt out of place, wiggle the suckers around and if your sure their good to go try......... I know you said it didn't have a controller but just for shits and giggles take off the glass and in front of the lens is a rectangular panel remove the 4 screws and verify there's nothing in the memory slot if there is yank it. If this doesn't help I would suspect you have a problemo with the IF board or better known as PWB-B. I'll ask a few of my techs if they can remember seeing this before which I think we have and it turned out to be the IFB.
        • nmfaxman
          • 1702
          Here are some samples of prints and copies.
          • nmfaxman
            • 1702
            Turned out to be bad CCD.
