I'm having problems with a c500 taking glossy stock through the bypass - other stocks are fine but with this particular stock it will always take the first sheet and jam on the 2nd (it will also take them as one-off prints no problem). I have it set for coated stock, 256gsm.
I think there's a function on the 6500 called 'CPM Down' that allows you to slow down prints, but what about the c500? Or is there any other work-around I could try (I don't mind how tricky it is!)?
