Bizhub C550 P-31 warning for K-imaging unit home position sensor error
  • jbosman
    • Aug 2025
    [Error Code] Bizhub C550 P-31 warning for K-imaging unit home position sensor error
    Does anyone have an answer to this problem?
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Bizhub C550 P-31 warning for K-imaging unit home position sensor error
    check to see if the transport system is binding at all, or if there is some thing broken or out of place.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • cushtyasgold
      • Sep 2011
      • 5
      It sounds like a problem with the Main Drive unit. On the back of this unit is two sensors you can try blowing them out.
      I have a couple of machines running with this P Code have not yet had any quality problems but I know it can lead to problems on some machines.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Ianizer
          • Jul 2011
          • 380
          Been doing battle with this one myself, on one machine.
          Even swapped the MPF-PWB... and that's where it got interesting... Had reseated the MFP board connecters for, oh I'd say the third time? Was running test copies, P-31 still came up, but was it less often? Probably wishful thinking... Then, as mysteriously as the nearfault appeared, it vanished.... Ooooo, I HATE it when that happens. Well, sort of a love/hate thing.
          Called it good and haven't been back. Yet. (I'll burn that bridge when I get to it.)
          I highly suspect the main drive unit; specifically, PS45 & PS46.
          -I
          My name Peggy.
          You got problem?
          • Kanini2k
            • 63
            • westvandude
              • Sep 2013
              • 31
              Our tech mentions to add another piece of foam on the blue image unit retainers so it forces the iu closer to the back of the machine. If the K IU moves forward it can damage the drive system. Big $.
              Not that related to your issue though.
              • Kanini2k
                • 63
                Thanks for the tip about the foam pad, we've already done that on the K unit earlier to avoid the problems connected with the IU not connecting correctly. I guess I have to take the machine apart then, now it's started to not register colors correctly, have to check if the main drive unit is OK or not. If anybody has any other tips for easier access to the main drive unit I'd appreciate it, not looking forward to take out all the mainboards etc...
                • nvram
                  • Jul 2009
                  • 40
                  These 2 sensors need cleaning, but be very careful not to damage the encoder, if the p31 continues without attention, the machine will also develop c225b error, this is due to the dcps failing.
                  si
                  • Kanini2k
                    • 63
                    Thanks for the tip nvram, I'll be careful. I've now taken the machine apart as far as I've gotten to the color and K pc drum motors, but do I really need to remove the color PC drum motor also to get to the PS45&PS46 sensors (K PC encoder sensor 1&2)? Want to avoid the adjustment procedure. Service manual doesn't show any pics of the sensors as they are part of the main drive assy.
                    Do i really need to remove the whole main drive assy to get to the sensors to clean them?? It seems like a lot of work just to get to the sensors, does anybody know where these sensors are in relation to the K PC drum motor for example?
                    Thanks a lot!
                    • avecosat
                      • Jun 2012
                      • 305
                      Thanks a lot!
                      No , you don´t need to remove the main drive unit but be careful and they are right behind the K PC drum motor , in BLSJ you have a bulletin about this sensors .
                      • copier tech
                        • 8172
                        I have the same issue but on a C552, is there away to blow out the sensors from inside the machine, say by removing all IU's then blower brush air through the back of the machine, or is that a bit hit & miss!?
                        • nvram
                          • Jul 2009
                          • 40
                          Unfortunately it's not that easy, you have to access it from the back.
                          • copier tech
                            • 8172
                            So what do I need to remove to clean these sensors on a C452? & how long should I allow to do it?
                            • Joana
                              • Feb 2018
                              • 14
                              I also want to know how to find these sensors to clean? I have c451
