C3461 error code /
  • Art
    • Jul 2025
    C3461 error code /
  • BIG PAPA
    Da Boss
    • 234
    Re: C3461 error code /
    Not sure exactly what you said, but to reset a fuser code power on while holding down, the utility/counter button and do the trouble reset. If problem returns you have a fuser issue.
    sigpic
    • Art
      BIG PAPA Thanks for your help,
      But I managed to reset the fuser fuse with a help of a friend, because I still have to reset the unit magenda.
      You know how to do this?
      • BIG PAPA
        Da Boss
        • 234
        To reset it you either need to replace it, or use a chip reseter. U can allow it to continue past end of life in service mode, but this will not clear the message. I believe it is under system 1 IU life stop setting. Then in enhanced security stop, 0, C once in service I think there is another setting as well, dont have a mchine to look at in shop.
        sigpic
