C550 with weird prints...
  • Michko
    • Sep 2010
    • 32
    [Misc] C550 with weird prints...
    Hey.
    So I have a machine that gives my client weird prints after a while.
    I suspect MFP board and maybe memory ?
    Never tried to scan.
    20111005165006253.pdf
  • Albonline
    • Sep 2008
    • 1153
    Re: C550 with weird prints...
    seen this before. turned out to be hv arc flipping out mfp board. check your contacts/grounds on the first and second transfer units.
    • habik
      • 2013
      ..nice Albonline...will keep that in mind..I had similar issue when printing B/W and it went away after a while, initially though its BK IU, when changed it improved, however not completely, still little ghosting left ..
      Will check again when with client to see if it improves
      Firmwares HERE
      • Michko
        • Sep 2010
        • 32
        How can a IU do this?
        It's impossible for IU to flip the image, as you can see the yellow to the right did.
        • habik
          • 2013
          You right I did not look all the way on your pdf to the right ....I missed that 90' turn
          There was/is however problem with Bk IU's and which has been cleared with new batch. Due to bad contact at the back, I had arcing there and it wss causing shifted image a.e ghosting...
          Firmwares HERE
          • Ianizer
            • Jul 2011
            • 380
            Hope I'm not jacking the thread, but I've been searching for some references on gradually pronounced mainscan color shift (up to several mms), culminating in P-21 nearfault codes. O/C front door clears code & puts color aright.
            Replaced LPH, PRCB and cleaned IDC sensors... Several hundred copies later, just dandy, life is grand... 'bout to bail and up pops P-21 again. @*&%$^... Oh for the love a Terry Karahura!
            -I
            My name Peggy.
            You got problem?
