konica 8050 j72-16
  • poco
    • Sep 2007
    • 7
    konica 8050 j72-16
    any help with this code is that sensor in inverter i keep gettting it when i try to use main tray or staple
  • SupertechNCISpfld
    code
    have you checked the sensors in 47 mode to see if they are working correctly. {ps13} and {ps704} jake il
    • random
      Does it do it in face up mode? If not the one way clutchs on the back of the inverter are stuffed
      • fernan
        • Jan 2008
        • 61
        just try to clean the sensors and check it's actuator maybe it's blocking the sensors and check it's spring
