problem on a c450
  • jokacross
    • 110
    problem on a c450
    I have a c450 that as been doing this: (see image) SKMBT_C45011101417480.jpg but this only happen when i make photocopies in black, but when printing from computer or photocopying in color mode doesn't occurred this problem. What do you think it is? thanks!
  • Gort
    Copier Demon
    • Oct 2011
    • 50
    Re: problem on a c450
    What is the image supposed to be? Are you copying something or is it a sample of background on a white paper?
    If there is an image not printing in black mode you may have a failed black CCD.
    Sorry, I do not have a cat in my avatar.
    • jokacross
      • 110
      Is a sample of background on a white paper!
      • mrwho
        Major Asshole!
        • 4299
        If you make a series of scans (in black and white, grayscale and color), does the problem occur on the resultin PDFs?
        Mascan42
        Ibid
        • jokacross
          • 110
          nop! I think not. But im going to test to be sure!
          • jokacross
            • 110
            I tested now and it is true the image stays blank!
            • jokacross
              • 110
              Problem solved. I just change the IU and solve the problem. It was a chipped IU that broken in a sudden.
              • mrwho
                Major Asshole!
                • 4299
                Nice. I was going to suggest that, but the fact that it printed OK had me confused.
                Mascan42
                Ibid
                • jokacross
                  • 110
                  to me to. But in fact It did that. The printings in the old IU they was really good compared with photocopies. But I note it that they print the same pattern but was much lighter then when photocoping. thanks a lot
