bizhub 350
  • debbie
    • Sep 2025
    [Misc] bizhub 350
    Could someone please tell me how to adjust the adf timing , im getting a black line from lead edge on my copy? Thanks
  • mo0651
    • 1054
    Re: bizhub 350
    Turn off/on the main power. The switch on lower left side, toward the rear of machine. this will initialize the scanner.
    • SPBE
      • Sep 2010
      • 70
      Re: bizhub 350
      Clean the slit glass.
      • JustManuals
        • Jan 2006
        • 9838
        Re: bizhub 350
        Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads -
        • debbie
          Re: bizhub 350
          This worked for first five copies then prob returned, any other thoughts on how to eliminate that leading edge line?
          • mo0651
            • 1054
            Re: bizhub 350
            Have you had work done to the copier recently? This is usually caused by a screw that was put in that is too long, or someone is copying books on the glass and pressing down real hard on the glass. Especially if it works for a little bit then comes back. The scanner is not going all the way to the left like it should.
            • debbie
              Re: bizhub 350
              I only cleaned the adf, no screws were removed. So its a home position problem?
              • SPBE
                • Sep 2010
                • 70
                Re: bizhub 350
                Is the left side of the scanner drooping down?
                • SmellsHot
                  Head Tech
                  • 512
                  Re: bizhub 350
                  In service mode, under PRINTER tab select EDGE ERASE. Make sure that these are set to 4mm and not bumped down any lower. Also make sure your scanner lock isn't engaged.
                  Everyone has the right to be stupid. Some people just abuse this privelage more than others
                  • emujo
                    • Jun 2009
                    • 3009
                    Re: bizhub 350
                    These adjustments are in SERVICE MODE/ ADF. mess around with the =/- setings and all should be good.
                    • mjunkaged
                      • 387
                      Re: bizhub 350
                      If it's an ADF (one-sided, feeds in at top left, exits underneath) then it could be worn out rollers. If edge erase is confirmed to be consistent. Try on the glass, if no black lines it's an alignment (broken hinge sockets/bent scanner) or reg/feeding problem (aka worn out feed rollers) or sensor timing/sticking problem. The PLASTIC hinge sockets on the ADF are known to break. They may look fine but if you pull them out the bottom sockets the steel pins fit into can be cracked. If the unit flops about when you grasp and move it left to right at the front or when you open it, I'd look at those.
                      I'm guessing plastic hinge sockets myself. Let us know.
                      • debbie
                        Re: bizhub 350
                        thank you all for your great input! turns out edge erase
                        was at 0 made the adj and copies look good. thanks again.
                        • mjunkaged
                          • 387
                          Re: bizhub 350
                          Now that I think about it , broken hinge-sockets give a different symptom: picture of the rollers under the ADF. My bad. Glad it was as simple as pushing a few buttons!
