konica minolta bizhub 350 display says there is no enough memory
  • javier4065
    • Feb 2007
    • 251
    When I make copies for example 30 originals by adf the copier stops and the display says the job has been deleted.Not enough remaining memory. what can I do to solve this problem.
  • JustManuals
    • Jan 2006
    • 9838
    Re: konica minolta bizhub 350 display says there is no enough memory
    Maybe adding more memory?
    Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads -
    Paul@justmanuals.com
    • SmellsHot
      Head Tech
      • 512
      Do you have extra memory chip installed? How about hard drive? What kind of originals do you have. Are you using some sort of colored paper? How much text is on the page?
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • mervyn
        • Jul 2011
        • 90
        You will need a hard drive to scan that many originals .
        • mjunkaged
          • 386
          No hard drive .....the machine should be able to scan up to 70 docs, if mem. serves on the specs.
          BUT if they're colored, or if the scanner is 'seeing' all black, it would fill up the system memory (mounted on the MFB/main board) as mentioned above.
          Make one copy and look at it.
          If all is normal, watch the memory counter on the bottom of display to see if one particular doc (all black, colored, full of image/photos?) is 'eating up ' the memory. If your memory isn't 100% free it could be occupied with unprinted/corrupt print jobs, if equipped with print option box. Or corrupt copy jobs I suppose, which would require a mem. clear. Be careful what you clear in there!
          When the memory is almost full, you could also stop the job, and only feed that many docs and see what the copies look like.
          You may have bad system memory, or some was removed. Or bad ccd filling up memory with bad scan.
          • mervyn
            • Jul 2011
            • 90
            You will be lucky to get anywhere near 70 pages on the base machine . Memory is only �� (32MB) on this model .
            • mjunkaged
              • 386
              70 pages with 5% or less fill...otherwise a mem. upgrade would be needed, yes. I was merely stating max page capacity. I probably shouldn't have mentioned that, good point.
              • aleksander
                • 378
                try to total clear your MFP. Then change the RAM in MFBS.
                If still doesn't work, add an expanded memory (optional).
                • k130
                  • Oct 2011
                  • 36
                  i met this problem before and i set the lowest resolution for scanning. but in your case is to make copy, so.. i dont know the solution. sorry.
