Konica 7013 H-Vlt Fuse disconnect
  • White_Toner
    • Aug 2009
    • 71
    [Error Code] Konica 7013 H-Vlt Fuse disconnect
    Hello to everybody!
    Machine Konica 7013. In diagnostic mode i can rad message :" H-Vlt Fuse disconnect". I had change fuse ( 0.1A ) in drum unit, but unsuccessfuly. Alarm diod lit and nothing more:-). What can i do else?
  • kingarthur
    • 1385
    Re: Konica 7013 H-Vlt Fuse disconnect
    Originally posted by White_Toner
    Hello to everybody!
    Not knowing this m/c, reading the code.......i would guess that there's a fuse gone in the high voltage unit, i've no idea why you've changed the drum fuse, i would suspect all that does is tells the m/c that a new drum unit has been fitted....so the first thing to do is check your HV unit....
