Bizhub C353 always Jamming
  • Gabriel
    • Jun 2006
    • 141
    When the machine is Ready it shows both paper trays available
    but neither of them works.
    Every time you try to make a copy you get a Jam
    The Feed, separation and pickup rollers were replaced in both trays
    I 'll replace the tray paper clutch
    Any help will be appreciated
    Regards
    Gabriel
  • aidil rashidi
    • Jun 2008
    • 33
    Re: Bizhub C353 always Jamming
    can you explain where the paper jam at?
    • minimerlin
      • 851
      Always a good idea to let us know the J code! have you checked all sensors on I/O mode?
      Please do not PM me without asking first.
      • copytechman
        • Nov 2008
        • 969
        Also a good idea to clean the shafts and oneways attached to the feed system while in there, they can slip, been there, done that!
        Regards!
        A.
        • Gabriel
          • Jun 2006
          • 141
          Sorry guys
          The jams are at the paper trays (paper is not picked-up at all)
          Short history:
          Service call-----paper jams from both paper trays
          1st. tec. -----call incomplete by parts (feed-sep-pickup rollers)
          2nd. tec ----parts replaced---- call incomplete---same problem
          They don't remember the jam(s) code(s)
          Now, the ball is in my side and need some advise before I go to customer office
          PS: Both lifter motors are working fine.
          Regards
          Gabriel
          • SPBE
            • Sep 2010
            • 70
            Well, the best thing to do would be to go to the machine and get the jam codes.
            • mo0651
              • 1054
              Doesn't this machine use feed clutches still? Or are they a motor? I see the tray feed units use clutches. Never had to replace one but I would definitely start with that. Happened alot with BH200 series.
              • Gabriel
                • Jun 2006
                • 141
                they use one clutch on each paper feed unit
                Regards
                Gabriel
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  So both trays simultaneously go bad? No feed attempt?
                  A jam code and Knowledgebase would be best for odd problems like this.
                  • copytechman
                    • Nov 2008
                    • 969
                    Could also be a bum transport motor M1 which runs tray one and two for drive, some machines, show jams before call for service codes. (Maybe blown ICP on engine board?), does the feed system rotate @ all when watched from the front with the tray cover off?
                    Regards.
                    A.
