New HDD on Fiery IC-406 (X3ety 30c-km)
  • Methmann
    • May 2009
    • 79
    Hi everyone
    I have a Fiery IC-406 (X3ety 30c-km), sitting on a Konica Minolta Bizhub C352, where the harddisk has broken down. So i have to install a new harddisk to the fiery. But i have only tried to install the system software to a older fiery, via parallel cable.
    I have the iso files with the system software(Ver. 1.01), so how do i get it to the new harddisk? I hope anyone can help me with a procedure? :-)
    Thanks in advance.
  • Methmann
    • May 2009
    • 79
    Re: New HDD on Fiery IC-406 (X3ety 30c-km)
    Nevermind. I think i have found the procedure, tried to mount the first iso file. And voila, a fine installer came, with the option to install via usb or ethernet cable. Nice :-) i thought it was much more complicated.
    • RRodgers
      • Jun 2009
      • 1947
      I usually burn it to a disk then copy the installer onto my local hd. Then run it. Don't have an IP on the computer you are using for the install and use a crossover. Be sure tp add the patches as well GL
      • Methmann
        • May 2009
        • 79
        #3 Okay, thank you :-)
        • dunero
          Hi, I have a fiery x3ety installed on KONICA MINOLTA BIZHUB C300, fiery is in French and I want to change the language, but I do not know where and how (I have not the fiery CD`s), could anyone make an image after CD`s
