Tech needed for BizHub Pro 1050EP
  • scotsman60
    • Mar 2011
    • 32
    I'm looking for a tech in the Orange County, California area to work on my BizHub Pro 1050EP.
    PM me and leave a contact number or email me at doug@beachmailing.com
    I have a fault on two drawrs out of the three on the large capacity feeder that I can't resolve.
    When I feed from drawer 4 in the PF, I get a J18-07 jam code.
    From the manual - this code says - "The PF exit sensor (PS99) does not turn ON within a specified period of time after the loop sensor /2 (PS94) turns ON."
    So I replaced the Exit sensor - no change
    If I pre-feed a sheet partially through the feed rollers, this sheet feeds fine but the jam code comes up on the second sheet.
    I relaced all of the paper feed rollers - didn't make any difference.
    I'm replaced the torque limiters on all drawers (they needed it anyway) - didn't help.
  • copytechman
    • Nov 2008
    • 947
    Re: Tech needed for BizHub Pro 1050EP
    Not sure which feeder it is but have seen cases where the conveying rollers (rubber ones) swell, especially the middle ones, something to look @/think about!
    Regards!
    A.
    • scotsman60
      • Mar 2011
      • 32
      Copytechman,
      Yep - I checked the transport rollers and they looked OK - I cleaned them with rubber conditioner and it didn't help althouh I didn't replace them.
      I'm wondering if the main drive mototo on the feeder might be going out and slowing down - making the whole paper transport slow down.
      I'm trying to avoid just replacing everything though.......
      • blago_vd
        • 38
        Check the couplings between the roller shaft and clutch shaft inside the PF. The easiest way is to remove the side cover of PF, to pull out the drawers and check.
        • RRodgers
          • Jun 2009
          • 1947
          do you work on weekends?
          • scotsman60
            • Mar 2011
            • 32
            blago_vd,
            Thanx.
            Which shaft are you talking about? The registrarion conveyance roller? (Item 10 in the drawing below) Looks like this is the shaft that should be driving the paper between the two sensors where it's reporting a problem...
            Doug
            • scotsman60
              • Mar 2011
              • 32
              I usually work sometime over the weekends - but not this weekend 'cause I'm out of town.
              Next weekend would be fine though.
              Do you work on these machines?
              • faultman
                • Nov 2009
                • 20
                think i had this once before when the pin had broken away the inside of the plastic gear (think it was item 19 or 15). This causes loss of drive to the feed, the gear just spins because the moulding for the pin to locate into is broken. Hope this helps!!!
                • RRodgers
                  • Jun 2009
                  • 1947
                  I'm trained on the 1050 but to be honest, I haven't seen one in forever.
                  • why1265
                    • Jun 2011
                    • 1
                    • scotsman60
                      • Mar 2011
                      • 32
                      faultman called it!!!!
                      Faultman and blado,
                      Got back to the shop this weekend and stripped down the trasnport drives inside the paper feeder and you called it exactly right.
                      The inside of the gear (Item 15) was completely destroyed so the drive pin was spinning but no drive was getting to the inner side of the coupling!!!
                      I ordered a new gear and should have the system up and running on all drawers next week.
                      Thanx for the help!!!!
                      Doug
                      • scotsman60
                        • Mar 2011
                        • 32
                        RRodgers called it too.....
                        This is exctly the gear that was stripped!!!!
                        Thanx again.
                        QUOTE=why1265;260781]check the pulley 26T inside the PF drive unit IMG_1416.jpg[/QUOTE]
