bizhub 600
  • BBCo
    • May 2011
    • 10
    bizhub 600
    help me please, my bizhub 600 WARMING UP,READY TO SCAN and when i enter to tech rep mode i find error code C D203. I has read this error report in this forum and the answer is FIRMWARE NEED TO UPGRADE. how can i do it,and where i can find the firmware?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2142
    Re: bizhub 600
    call a technician.
    • Darren King
      copiertech
      • 652
      Re: bizhub 600
      The only person that has access to firmware is an authorized Konica Minolta technician.
      Darren
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Re: bizhub 600
        Firmware does not fix shit most of the time. If it is stuck in warm up, the aidc sensor next to the drum could be dirty. Just a little toner on it will cause the machine to stay in warm up.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1076
          Re: bizhub 600
          BBCo You have just received 3 great answers. I would recommend you read all 3 then re-visit the first. An untrained or inexperienced person messing with the firmware or the drum carriage in this machine is only asking for bigger problems.
          Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
          Now into Ip TV KODI Boxes
          • jarwil
            • Jun 2009
            • 61
            Re: bizhub 600
            could be irty drum sensor. A service on the machine should fix
            • BBCo
              • May 2011
              • 10
              Re: bizhub 600
              Thank for your comment for this trouble.. i am a tech,,and i has clean sensor,and i am sure the problem accured because of software system, i call this trouble with " a worng minolta security system"
              And now i has fix the probem without " ORIGINAL FIRMWARE " I say thank so much to my "software editing team"..
              Keep on your life, and the machine is only the machine
