C0301 on a C352
  • mrwho
    Major Asshole!
    • 4305
    [Error Code] C0301 on a C352
    This one is driving me nuts.
    Already:
    - Swapped the fan with a working one
    - Measured wire continuity from the fan to the PWB
    - Swapped PWB with a working one
    - Did NVRAM Reset
    - Updated firmware
    What's left is to swap the PSU, but the wiring diagram shows that this fan shares the same 5v with other working fans, so I highly doubt it.
    Any tips on this?
    Thanks.
    Mascan42
    Ibid
  • mrwho
    Major Asshole!
    • 4305
    Re: C0301 on a C352
    Everything points to the PSU - Ordered one.
    I'll let you know how it ends.
    Cheers!
    Mascan42
    Ibid
    • DCPS
      • Mar 2008
      • 116
      Re: C0301 on a C352
      Just in case. Sorry for the question but did you exchange the correct motor (M10) on the right door assy? If yes it is strange because the control signal for the motor is coming from motor control board and not from PSU. But as we know everything is possible.
      • mrwho
        Major Asshole!
        • 4305
        Re: C0301 on a C352
        Well, the manual tells me this errors points to the M17, which is the toner suction fan right in the front of the PSU. And, rightly so, the fan isn't moving.
        We've tried the PSU on another machine and, as expected, the same fan isn't moving, so the PSU is to blame.
        Are you telling me this motor is burning up the PSU?
        Mascan42
        Ibid
        • DCPS
          • Mar 2008
          • 116
          Re: C0301 on a C352
          The info i provided was based on these documents and my experiences on C250/C252. But in your case if you have tried the PSU on an other machine and it produced the same error then it means that is definitely broken.
          It' a little bit confusing because as you can see from the shema there is a M10 but in the service manual and parts manual there is no reference about that. But according to the error 0301 in the SM the problematic unit is the "suction fan motor" and not the "toner suction fan motor" which you are referring to. But anyway i don't want to make the case more complicated.
          • Darren King
            copiertech
            • 652
            Re: C0301 on a C352
            C0301, according to the manual, refers to a failed suction fan. This fan is in the right side door. It can't be ordered separately it has to be ordered with the door as an assembly.
            Hope this helps
            Darren
