C253 Faint Print/copies after turn off then on
  • Jonny
    • Nov 2011
    • 11
    [CQ] C253 Faint Print/copies after turn off then on
    Hi Chaps
    Ive got a very strange fault on a C253.When the m/c is turned off it goes faint and the only way to recover it is to run through the gradations then just dont turn it off.
    So far we have changed:Ram pack,PRCB,DIMMS1&2,all Print Heads,MFPB,DCPU,HV UNIT,New Image units,Transfer belt,Transfer Roller and firmware is the latest.
    Many Thanks
    Jonny
  • habik
    • 2013
    Re: C253 Faint Print/copies after turn off then on
    Originally posted by Jonny
    Hi Chaps
    Many Thanks
    Jonny
    Except HDD and NVRAM and Service ROM you changed everything... wow..i'd suspect Service ROM or NVRAM..try NVRAM recovery.
    Main question is it on COPY or Print that it goes faint?
    Firmwares HERE
    • Jonny
      • Nov 2011
      • 11
      Yes it is on copies and prints and i forgot to put NVRAM on the list. I have tryed two NVRAM packs.
      Thanks Jonny
      • empiru
        • Feb 2011
        • 229
        Hi!
        I am very curious what solution did you find to this problem (if you did find any).
        I have the same problem now; the machine is also C253 and the faint copies/prints are appearing randomly, both color and black.
        Thanks in advance!
        I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
        • Jonny
          • Nov 2011
          • 11
          Originally posted by empiru
          Hi!
          Thanks in advance!
          Hi unfortunately i did not fix it :-( Konica Minolta came in and tried for a day to repair it and in the end it was sent back to their workshop.
          They gave use an equivalent machine to replace it and we never heard anything more.
