c220 Not loading the firmwire
  • bkamoga
    • Oct 2011
    • 31
    [Misc] c220 Not loading the firmwire
    l have a c220 and it is not loading the firm ware for the MFP lt shows NG
    it loads all the firm ware for all others like the ADF, scanner, PRCB
    but for the MFP it shows NG.
    and when l restart the machine it doeznot start to complete,
    lt stops on the white screen
    the firm ware i use is the lattest one
    what should l do some help pliz...........
  • kingarthur
    • 1369
    Re: c220 Not loading the firmwire
    i think that there are problems associated with some versions of firmware..apparently it's not the firmware..but certain boards are "different"..."due to the tsunami"...so not all firmware will go into every version of MFP...sorry it's a bit vague...you might have to find an earlier version of firmware
    • szanka
      • Dec 2011
      • 29
      kingarthur is correct, if you open right door and you see a square sticker (i think it was green or red), you need to load certain firmware.
      • tech51
        • 846
        Also on the latest firmware you have to update the boot rom. There is a button on the first screen that appears when you switch the machine on with your usb stick in. Press that. If the machine needs it, it will update, if not it will tell you the latest version is already installed. Do this before updating the rest of the firmware. The latest firmware is backwards compatable with all previous versions of boards and I 've had no issues doing firmware updates on this product. Hope this helps...
        • DCPS
          • Mar 2008
          • 116
          I think the Japan earthquake problem is referring on scanner FW and not MFPB FW on these models. It's only Scanner FW which deffers. So in your case first of all i would suggest you to use an other USB Stick or it may be the MFPB which is defect. In any case you should also try an older FW for example 90 and see what happens. Anyway what's the reason you wanted to update the machine and how old is she?
          • bkamoga
            • Oct 2011
            • 31
            l have tried to all the steps told but no good result yet
            the firm w
            ire i load is of the version aoedoyo-fooo-gc7-59(00)
            is it of the up to d
            ate firmwire pliz some help what should l do
            th
            aks for the results
            • jrf
              • 142
              Try selecting only MFP and it may load, this happened to me on a C452 , good luck
              • bkamoga
                • Oct 2011
                • 31
                l have tried to all the steps told but no good result yet even when l change and download only the MFP and the reson why l was upgrading the firm wire was that the machine could bring an error code 2555 and 2556 even when l change all the componets like PRCB, hopper section , relay board , develping units and asked 4 help and there was no reply. but now it has developed some other problems
                • habik
                  • 2013
                  May sound silly but have you tried Trouble Reset? Are you using OEM toner?
                  Firmwares HERE
                  • DCPS
                    • Mar 2008
                    • 116
                    the firm w
                    th
                    aks for the results
                    If you have tried all these steps then it can only be the MFPB. I guess if you start the machine now you see only the sand glass on the display and machine will not boot any further. But again. GC7-59 is a special one based on 59 mass production. Have you already tried i.e 90, B8, C6 but always the mass productions of these FW?
                    • bkamoga
                      • Oct 2011
                      • 31
                      l have tried all the solution given to me but things are no working out well
                      now l want to change the MFP but how much is the new MFPsome help
                      • Zeldaman
                        • Mar 2011
                        • 946
                        • emujo
                          • Jun 2009
                          • 3009
                          Had one that showed MFP controller NG. Another tech recommended this...Disregard it, cycle power and try again, it took 12 attempts, but finally it worked. Had the fax fail once also, after the 4th attempt it worked. Not sure why, but it sure beats paying for a new OACB. Emujo
                          PS what is it about spelling firmware correctly????
                          • Mooseface2r
                            • Jan 2011
                            • 114
                            I had a similar thing where the MFP firmware wouldnt load. tried a diffent usb stick and it worked. iv seen a few hang at the hourglass tho. normaly just completely power down, plug out and it will work next time you boot.
                            • erayyurukel
                              • Jul 2021
                              • 2
                              hello my konica minolta c220 printers have c-186 code problem i have a problem for firmware update exe if you have this program can you send it to me
                              eryrkl@gmail.com
                              please send me
