c6500 printing problem
  • jzheld
    • Sep 2010
    • 162
    c6500 printing magenta and cyan like on the picture, did all sort of calibration still have it, yellow and black print solid.
    Any idea what can be wrong?
  • JustManuals
    • Jan 2006
    • 9838
    Re: c6500 printing problem
    Paul@justmanuals.com
    • Gaffers01
      • May 2011
      • 334
      Looks like a developer problem to me, try replacing yellow dev and see if it improves.
      • Itsthepaper
        Supervisor
        • Dec 2007
        • 91
        The image looks like the charge grid pattern, try swapping the charge coronas assemblies and see if the problem changes.
        Love the Job Love the Work.
        • anothertech
          • 1759
          I'm with Gaffers01 on this, replace cyan and magenta dev. and all will be well. What kind of toner are they using?
          • rangertech
            • Jun 2011
            • 40
            i'm with Gaffers01 too, replace developer for solve problem..
            • jzheld
              • Sep 2010
              • 162
              I was thinking about developer too, but I changed all the developer no that long ago, it's not even close to 100% right now, what could cause that?
              • jzheld
                • Sep 2010
                • 162
                ok if somebody will have that problem, I replaced magenta developer, that solved the problem
                • dljorg
                  • Sep 2009
                  • 93
                  Try moving the dev units to different positions and then running a test pattern 53 to check the result. Put tape over the toner entry to prevent contamination. Yuo are looking for the problem to stay in that spot or move with the dev unit.
                  If its not the developer then the laser is a candidate. Some C6500's had flaky lasers, fixed in the C6501
