BIZHUB 250P
  • ARTISER
    • Jun 2025
    BIZHUB 250P
    Good morning, TO SEE IF YOU CAN HELP ME THAT HE HAS THE PROBLEM ARISE.
    I ordered UNIT CHANGE IMAGE COULD NOT SEND ANY FILE TO PRINT, AS WAS LOCKED, YOU HAVE CHANGED THE CHIPS UNITS, took off on the display, BUT THEN GETS READY TO PRINT.
    PLACES TO SEND A FILE ERROR C-FD07, THIS IS NOT ERROR, PLEASE TURN ON THE MACHINE AND DOES NOT SEEM TO NORMAL HEATING CYCLE AS THOSE SECONDS BEFORE AND STAYS IN PRINT LIST, BUT AT THE ENVA FILE, return error, and I have no way of knowing what is.
    THANKS AND HAPPY NEW YEAR
  • JustManuals
    • Jan 2006
    • 9838
    Re: BIZHUB 250P
    Paul@justmanuals.com
    • ARTISER
      Re: BIZHUB 250P
      THANK THE MANUAL OF SERVICE AND HAVE
      PUT IN THE MANUAL IS A ERROR
      ASIC10 TIMEOUT NUMBER OF DMA
      thanns teh manual of service and have
      put in the manual is a error
      ASIC10 TIMEOUT NUMBER OF DMA UNDER OPERATION AND TRANSFER COMPLETION
      LINE=0 DMA_D
      rank c (on off switch power)
      I need is how to interpret the error code, do not know what that means, do not understand the problem.
      if I send a file to print, after a while after giving the code again
      • ARTISER
        Re: BIZHUB 250P
        OK THANK YOU FOR ALL
        The mistake has been solved
        A configuration problem IN THE SERVICE MODE
        Thanks and happy NEW YEAR
