Bizhub C652 with error C9901.
  • ReoNeo
    • Dec 2008
    • 25
    [Error Code] Bizhub C652 with error C9901.
    Can someone please help with an issue we have on a Vl6522c.
    I find something in the Konica Solution report, regarding this issue, but the customer have no setting for transparencies.
    We have tried to put in the latest firmware, and also changed complete by pass tray. With no luck.
    The scenario is as follow.
    Customer wants to copy from the by pass tray, it move the paper 1 cm in to the machine, the by pass tray moves downwards and show paper jam.
    We have tried a variety off paper from 80 to 250g paper.
    And in the counter list is showing only error 9901, and nothing else.
    And after that, the machine must be restarted with the main switch.'
    Have changed Printer control board, mfp board and ram.
    • 23010
    Re: Bizhub C652 with error C9901.
    99-01 jam is a controller stop due to mis-matched paper size or media type.
    I suggest that you focus on just one paper size for now. Insert the paper in the bypass tray. What size is displayed on the panel? If it doesn't match, there's your problem. Try various standard paper sizes to determine if they are properly recognized.
    The tray width adjustment may resolve this issue for you:
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      TAUS1002222EN01
      Incorrect transparencies and/or machine settings.
      Notebizhub C452/C552/C652
      For minimum firmware version 26:
      For firmware version 24 or earlier:
      a. Set the software switch.
      • Service Mode a System 2 a Software SW
      • SW No.: 59
      • HEX setting: 01 (press FIX)
      b. Set the Security mode.
      • Security mode a Engine FW DipSW
      • Select [1]
      c. Turn the Main SW OFF/ON (wait a few seconds between turning the MFP OFF and then back ON).
