C452 with J72-43 error
  • kingarthur
    • 1301
    Happy new year chaps & chapesses
    Got a biz C452 after 8 months working ok,suddenly coming up with J72-43 error when punching, manual indicates punch home position, have tried another brand new punch unit, without success...anyone had this, going back now to check the PS sensors in the conveyance unit, but cant see it being them as when not punching, the m/c works fine
    cheers
  • kingarthur
    • 1301
    Re: C452 with J72-43 error
    well i think i've solved it, luckily the customer is right next door, i found a TAD ref a PK516,,,the customer had a PK517, it says that when setting them up, dont select "EU4 holes", which is what i had done, as soon as i selelcted "2/4 holes" it started working...unfortunately, it doesn't state this in the set up instructions, and it's taken about 8 months to go wrong
    • mrwho
      Major Asshole!
      • 4299
      Thanks for the tip! Glad you sorted it out!
      Mascan42
      Ibid
