Konica Minolta C20 Printing Problems
  • Mooseface2r
    • Jan 2011
    • 114
    I have a C20 causing me some problems today. It prints from the machine fine although when printing from the PC (USB) it just prints blocks of colour down the page, the sort of blocks that get put on the transfer belt when it is warming up. I have reloaded the FW, Then i disconected deleted the driver and reinstalled the cable and let it install the driver again, plug and play style. still did it though. so i installed a different print driver, it worked fine from this driver.......but then i got a call from the customer again saying it was doing it again.....im taking my laptop in tomorrow to see what it does when i plug and play to try to rule out the machine.......anyone got any other ideas.
  • gurko_gg
    Prod.Line Technician
    • Sep 2011
    • 43
    Re: Konica Minolta C20 Printing Problems
    Hi,
    can u upload images about problem ?
    Regards
    • Mooseface2r
      • Jan 2011
      • 114
      Sample Attatched.
      I have heard it would be the IDE Cover.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Originally posted by Mooseface2r
          Sample Attatched.
          So far you have done everything I would do. However I have found that the calibrations that are in the menu , do work on other color boxes. I have used the aidc calibration to solve 2 different problems that I normally would have changed the drum for. I would recalibrate, and then if it still does not work, maybe try a different transfer belt, as I have had issues in the past.
          • Mooseface2r
            • Jan 2011
            • 114
            Resolution: the IDE cover was not opening correctly. Fixed it open and it worked first time, warmed up in seconds.....not sure why this only effected printing but it did...... as far as i know the cover is only there to stop dirt/toner getting on the sensor.
              • 23008
              How interesting! Thanks for sharing. =^..^=
