Konica Minolta Bizhub C250 Black Printing Problem
  • Naveed Shahid
    • May 2008
    • 162
    [Misc] Konica Minolta Bizhub C250 Black Printing Problem
    Hello Every One ,
    Deal All I am facing a problem on konica Minolta biz hub c250 because of dust reason i opens yellow,cyan,magenta,black laser units i cleaned the glasses and returned back after fixings laser units once i makes copies its coming different image black image coming half i am attaching test prints black and colors so u can see half print not come
    yellow,cyan,magenta is ok
    and also coming warning p-9,p-21
    can any one send me perfect solution
    All Image units is new
    best regards
    Naveed Shahid
    Kingdom Of Bahrain
  • Dickie
    • Nov 2011
    • 190
    Re: Konica Minolta Bizhub C250 Black Printing Problem
    If it was o.k on black before you started it must be something you have done.
    The first obvious thing to do is remove and refit the black laser again breaking and re-making all electrical connections.
    I would guess it's not located correctly at the front or the rear.
    From memory it locates on a pip at the rear and twists to the right to lock it in at the front, they are very fiddly to refit correctly!
    I seem to recall this type of missing image from the training course way back when it was a new product
    • Mooseface2r
      • Jan 2011
      • 114
      If you opened up the PH units you have probably brought on all sorts of problems. as far as i know the PH units are'nt designed to be opened.
      • Mooseface2r
        • Jan 2011
        • 114
        cant remember if they are interchangable but you could try swap the magenta for example with the black and see if the problem moves. if it does id change the black PH unit
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Don't waste your time. Not interchangeable. The copier will ask for the correct image unit if you try this. Each unit has a small circuit board chip that the copier uses to identify the proper IU in each slot.
          Agree with Dickie....focus your efforts on the laser unit.
          • kingarthur
            • 1301
            i'll think you'll find...that's what "moose" meant when he said the "PH"...printheads....
            • blazebusiness
              • 1250
              My bad..sorry. I forgot that the lasers are referred to as printheads on this machine......LOL. Thanks for the correction.
              • Mooseface2r
                • Jan 2011
                • 114
                The PH units are all seperate units sold as a set of 4, as they are all setup together i think
                • Darren King
                  copiertech
                  • 652
                  The printheads on this machine are interchangable so swapping the black with one of the colours would troubleshoot the problem.
                  Darren
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    You did not reinstall the black laser unit correctly. Ensure its located properly in its mounting position.
                    The failed colour registration and other P errors are because stabilization cannot be done without black fully functional.
                    • Naveed Shahid
                      • May 2008
                      • 162
                      Hello Every One ,
                      Thanks Guys for kind support i really appreciate you guys I solved my problem
                      thanks all of u and copytechnet
                      see u
                      naveed
                      • mrwho
                        Major Asshole!
                        • 4299
                        Hello Every One ,
                        see u
                        naveed
                        The best way to thank the forum would be to share with us how you solved your problem.
                        Cheers!
                        Mascan42
                        Ibid
                        • ck1
                          • 485
                          Cheers!
                          Agree with you mrwho
