C452 Fixing problem with Thick paper (250 gr.)
  • Laserbeam
    • Aug 2011
    • 152
    [CQ] C452 Fixing problem with Thick paper (250 gr.)
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: C452 Fixing problem with Thick paper (250 gr.)
    Media_Guide_Consumer_Web.pdf
    Have you reviewed the Konica Minolta media guide for that model? Attatching a copy for you. It shows what paper will work with that unit. I would consider that as a possible cause before replacing the fuser.
    • mo0651
      • 1054
      Are the fuser rollers showing buildup?
      • emujo
        • Jun 2009
        • 3009
        Had a similar problem, similar CQ..cust was leaving trays set at thick 3 settings just to save time, and running predominatly plain (20#). After 500-1k copies, melted toner was thrown over every componant in the fuser, you could see the build up dripping down and contacting the fuser rollers. Your paper, according to the media guide, is in specs and can be run from any tray or bypass at thick 3 setting. Emujo
