E0070 on a minolta 2050
  • Previous Board Post
    what is a E0070 on a minolta 2050?
    Re:E0070 on a minolta 2050
    If you mean C0070 it means the toner bottle is not turning. Check the bottle, if it is turning clean the bottle home sensor. If it doesn\\\'t turn replace the black flag that connects to the toner motor, they crack and won\\\'t thrun the bottle.
    • Stratford
      c0070 is Main hopper Toner Replaenishing Motor error.
      the minolta\'s toner bottle is so closed at each model, just make sure it is a correct toner bottle in the machine, the different bottle could be forced into the toner hopper.
      • drewhew
        how do you clear the error after you have checked motor et al??
