black drum error
  • scottengineer
    • Oct 2011
    • 9
    #16
    Re: black drum error
    hi is it new oem drum units you are fitting or drum kits? is it possible you are fitting kits and have a couple of bad chips? we have all had it. i do think you should upgrade to the newest firmware it is the first thing km tech will ask
    • malthus
      • 29
      #17
      u must be bored this weekend scott
      • scottengineer
        • Oct 2011
        • 9
        #18
        very mate
        • copier tech
          • 8153
          #19
          Has your local chippy run out of deep fried Mars Bars?
          • JR2ALTA
            • Feb 2010
            • 2033
            #20
            I had this problem. And he's not crazy the machine will intermittenly say "drum error k"
            Per koncia I replaced both the PRCB and the Front Rely Board (little board the dev units plug into)
            It was covered under warranty so I didnt bother to find out which one was the real fix, because again it was intermittent and I didn't want another call back.
