Di 2510 &b 250 Clutches
  • Rudi
    • Jun 2007
    • 251
    Hi All , Whats Up With The Paper Take-up Clutches On These Machines Especially The Top Drawer I Had This Problem On The 2510 And Thought It Would Be Sorted Out With The B 250 But Now I Get Both Giving The Same Problem Alot.does Someone Maybe Have A Sollution To This Apart From Just Replacing As I Am Sick Of Replacing Them Already.
    Regards
    Rudi
  • bgbas
    • Feb 2007
    • 60
    not other than cleaning as much grease off the gears as you can so it doesn't contaminate the clutch again
    • superfly
      "Can i make a quick copy"
      • Dec 2007
      • 16
      lol... yea, there are also two clutches in the duplax path that are loaded with grease! fun-fun!
      • Scott_Lewis
        • Mar 2007
        • 519
        Crap!! You tell'n me they still don't have it fixed
        • wagon
          Village Idiot
          • Dec 2006
          • 654
          The grease comes off the gears and migrates along onto the clutch. Clean off the excess grease & change the clutch. I got pretty quick at changing those top drawer clutches... a whisker over half and hour start to finish (bloody expensive car parking!).
          If you are hitting your head up against a wall it always feels better when you stop.
          • halia_merah
            • Sep 2007
            • 28
            I'm agreed wit u Wagon..
            • alexn257
              hi will what i found on mine was that the first drew has a crack in it. the other thing was the white clips the lock the drew in when u close it those were going bad too. so what would happen was when your using that drew the tray will pop open lil bet. all most every machine i go to i find the drew cracked. check out this Bulletin 5528 in konicaminolta you'll see where it cracks. will hope this helps
              • kingarthur
                • 1369
                Regards
                Rudi
                you don't have to change the clutch, I strip them down & clean them & have had no more problems
                • ni311
                  • May 2008
                  • 658
                  Sorry kingarthur, but I don't agree with you. Once I have the machine wide open in front of me, I prefer changing them rather than clean them. In the appropriate future you'll have to change them with new ones, so why working twice? Besides of this, from what I know it's not so expensive, around $25 per clutch.
                  Konica Minolta Error Codes - Explanations and Solutions
