Problem with bizhub C253
  • ercha85
    • 7
    Hi, everyone. I have KM bizhub c253, and few days ago my printer started to act strangely. First, when I turn the printer I hear some loud noise, and then during printing I hear same noise. In one moment on printer screen appears an error code C3101, and when I open a front door, and close it, that error removes. Also, for couple times on screen appears note that I had to check Waste toner cartridge. Does anybody know what could be a problem?
    Thanks.
  • ineo+6501
    • Mar 2010
    • 262
    Re: Problem with bizhub C253
    C3101 is a fusing roller separation failure. Check that there is nothing jammed in the fuser unit.
    You may need a new fuser unit.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • ercha85
        • 7
        edit: Also, I notice that about a minute after printing of something, I heard same noise (like some gear stroke some other part) and thats repeated on few minutes, and lest for 1-2 seconds. Does anybody have some idea? There is no more error c-3101, only loud noise, and there is message that I should check Waste toner box, but I assume that this loud noise from printer and this message are in connection...
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Gear grinding noise during printing and warmup and periodically as transfer belt rotates along with check waste toner box means its time to buy a new machine.
          Unless you feel like doing the 20+ hour job of removing the obstuction in one of the toner hoppers.
          Course, it might not be that, and i hope it isnt ( for your sake!)
          • blaze2000
            • Sep 2010
            • 232
            Fuser retraction motor failure most likely, replace that.Your fuser unit probably might need replacement as well, you will have to physically check it out to determine that. The waste toner is independent of the fusing system and noises you have. Replace or empty out your waste toner bottle.
            The sensor for motor retraction is also possibly a suspect part. Check PS38 for proper operation.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              The times ive seen the jammed hopper its from a plastic slug from inside the toner cartrige left in there from manufacturing. Realisticly if proven so, km should be responcible for all of these repairs as thats just piss poor.
              • JSC
                Gimp
                • Dec 2006
                • 618
                It sounds like you have some clumpy toner in the toner system, its normally the Yellow & a complete shit to fix. It takes me about 4 to 6 hours I have done 3 so far.
                Good luck
                The gene pool could use a little chlorine.
                • Vy2
                  • Mar 2013
                  • 27
                  Good luck
                  How did you fix it? I am having the same problem right now. I had replaced a yellow toner and it took forever to warm up and then when it finally warmed up, it would make this loud noise in the back door.
                  • Mitch Barron
                    • Mar 2013
                    • 180
                    Sounds to me that its the transport on the transfer belt. Take out the transfer belt and check the rest toner transport cannal. There should be 3 screws holding one side (metal plate) on and when removed you can see inside to the transport auger. Its probably blocked with clumpy toner...suck it out....replace the cover and try again. 90% sure thats the problem. No biggy. Just my opinion. >Best of luck to ya. Oh and happy holidays to all you tech heads out there in techy land. I got a 3 week holday with beer and my deck come saturday. Wooooohooo!!
                    • Vy2
                      • Mar 2013
                      • 27
                      Yep that solved it Though I had a hard time finding the side you mentioned to take it out. It's printing, but after a few pages, it would start to make the noise again. I am trying a different toner to see if it helps.
                      Have a good holiday!
                      • Vy2
                        • Mar 2013
                        • 27
                        Originally posted by Vy2
                        Yep that solved it Though I had a hard time finding the side you mentioned to take it out. It's printing, but after a few pages, it would start to make the noise again. I am trying a different toner to see if it helps. Have a good holiday!
                        Different toner didn't help. I stripped down the copier to try and get to the hoppers so I can de-clog it....stuck at how to get the hoppers out. I managed to remove the back layers...Help!
                        • JR2ALTA
                          • Feb 2010
                          • 2033
                          Hate to tell you brother, but your machine is a brick.
                          I hope you work for a dealer who can replace it.
                          I work for a big dealer with 3 full time shop techs, and still condemned three c353 series because of this problem.
                          There was a good post about this a while ago, but CTN search function, is well...
                          The toner tube system is built into the machine beyond servicing. You either get lucky and vacuum out of the clump or like i said, brick.
                          • Mitch Barron
                            • Mar 2013
                            • 180
                            Dont give up. You have already gone this far, may as well give it a go. There was a video just posted about the auger mechanisms getting pulled out and cleaned. Doesnt go into much detail about disassembly, but you can have a look at what the parts look like and how far you need to go. Good video overall. Have a peek. Might help. I have never had to do the job yet....looks icky. Oevrall might learn something. Have a good one! All the best. Last day!
                            • Vy2
                              • Mar 2013
                              • 27
                              Dont give up. You have already gone this far, may as well give it a go. There was a video just posted about the auger mechanisms getting pulled out and cleaned. Doesnt go into much detail about disassembly, but you can have a look at what the parts look like and how far you need to go. Good video overall. Have a peek. Might help. I have never had to do the job yet....looks icky. Oevrall might learn something. Have a good one! All the best. Last day! Develop Ineo +253 Toner Compacted in Toner supply auger (machine view) - YouTube
                              My thought (about giving up) exactly this morning. I am so deep in already, might as well. I had one person tell me to re-assemble it and change the yellow IU....i doubt i'm doing that. =D
