bizhub 350 fusing parts
  • goldencup
    • Nov 2008
    • 366
    Hi, i have a parts guide manual of bizhub 350 but some parts are not indicated like in the fusing section. Here are the following:
    Upper Roller
    Upper Roller Bushing
    Lower Roller
    Heater Lamp
    Thermostat
    Does anyone have a part number of these? Thank you very much.
  • kingarthur
    • 1369
    Re: bizhub 350 fusing parts
    thats because you're supposed to replace the whole unit, however Katun sell the rollers
    • goldencup
      • Nov 2008
      • 366
      ...ah, okay. that's why Thank you for the reply
      • Hansoon
        • Sep 2007
        • 3389
        Parts are largely identical to Di-3510 which can be ordered separate.
        Hans
        • Don N.
          • Nov 2011
          • 409
          We've been taping the thermistors to try and get more life since that's where 90% seem to cut through first.
          • Don N.
            • Nov 2011
            • 409
            Copylite sells the exit tension rollers & seps.
