bizhub 501 won't print now
    • 23010
    It's a new install. It did print at install, but the web interface was a little flakey. The addressbook would pull up the page, but would not store addressbook entries. The message was "-----TagMissing". I successfully stored addressbook entries from the machine panel. 4 days after installing drivers I get a callback "Won't print".
    Sure enough, it won't ping on the network or from a crossover cable and my laptop. The web interface is responsive, and the machine will print counter pages, but the Printer Settings button has vanished from the Utility/Counter button.
    Yesterday I installed a OACB (control board). It does ping now but still won't print. Plus I got a little bonus: "License Management Error Occurred." I don't exactly understand the garble in the manual, but I gather that something must be Activated. Reloading firmware did not fix anything. The addressbook is saving properly now.
    As you may be able to tell, I'm not very familiar with this machine. Any hints? What does the CF card do? How about the fat capacitor mounted on the little square board to CN2601/CN2602?
    The IP address requested by the customer's IT was a little unusual, but worked fine initially. Do you see any problem with it?:
    10.31.58.142
    255.255.254.0
    10.31.58.26
    Is this a variation of a Class C address, or something totally different? I'm preparing myself for another brain busting explanation.
    Yes teckat, I know you can't respond to that first post. =^..^=
  • Glaander
    • Oct 2010
    • 33
    Re: bizhub 501 won't print now
    in order to get 361,421,501 to print, it must install the ic-207 as print controller, the ic-204 will not work on 501, only works for 420,360, and 500
    • mo0651
      • 1054
      Re-initialize network settings on 501. Are you getting connection to board. the Lights should be blinking.
      • Glaander
        • Oct 2010
        • 33
        is not the network, he is missing the printer setting tab, which meants ic-207 is not there or not working
        source from
        and all the options you need -- including an
        IC-207 Image Controller that powers comprehensive print/scan functionality.
        • Avskrap
          Partner in crime
          • Jul 2011
          • 160
          Check the IC slot on the OACB - It should be there since I've never seen a 501 without it, but you never know... Easy to find (just to the left of the DIMMs), or you could check the installation manual for it (it's up on CSES, ofcourse). Might be a bad contact or something.
          If you've changed the OACB there might be some license codes you need to enter, perhaps for the IC-207. Check the Infohub for the codes and so forth, I've never actually done it on this series...
          • mo0651
            • 1054
            There is 2 spots on the board for a chip. make sure it's in the correct one.
            • Avskrap
              Partner in crime
              • Jul 2011
              • 160
              It's the right one (marked with "IC" for your convenience) IIRC
              Regarding your subnet question, it's a 23 bit net, 510 hosts at most. Quite normal!
              • emujo
                • Jun 2009
                • 3009
                Go into admin mode...turn off TCP/IP..power cycle..turn TCP/IP settings back on..Power cycle..when network settings come back, put MFP back into DHCP then cycle power again. If it pulls an address (assuming a DHCP environment), go into user mode, printer settings, print reports...If you can get to this point, then the IC chip is installed correctly, if not then you may have a bad IC...License error can be caused by sn discrepency. Did you verify/re-enter sn in service mode..? Emujo
                  • 23010
                  I did not re-enter serial number in service mode. If I re-install the original OACB will my serial number come back? My suspicion is that when I pulled the capacitor PWB I lost backup memory. and the same thing will happen when I reverse the process.
                  source from
                  bizhub 501 Office Printer Scanner from Konica Minoltaand all the options you need -- including an
                  There is no ic-207. both sockets are open. That sounds like a really good place to start.
                  • emujo
                    • Jun 2009
                    • 3009
                    So it sounds like you swapped OACBs and forgot to swap the print chip, and didn't re-enter the s/n..I think if you address these issues you might have a printer again Emujo
                    • SmellsHot
                      Head Tech
                      • 512
                      Might have to reload your CF card if your still having issues! info is on knowledgebase
                      Everyone has the right to be stupid. Some people just abuse this privelage more than others
                        • 23010
                        Easy as cake!
                        Re-installed the original OACB. Message gone.
                        Installed IC-207. Now it prints.
                        It's just strange that you can assign an address to the MFP, yet it's not print ready.
                        Thanks for the help, everyone. =^..^=
                        • TheOwl
                          • Nov 2008
                          • 1732
                          Even though some machines aren't print ready, they are sometimes scan ready out of the box.
                          You can also connect a machine to the network for purposes such as managment of the device so that you know when it is out of toner, has a paper jam and other situations with the use of software such as PageScope Enterprise Suite or Webjet Admin.
                          When I get presented the chance to connect a machine to the network that isn't utilised as a printer / scanner, I do purely for the added bonus of status notifications or meter readings sent from the machine back to myself.
