bizhub c363 with a c1194
  • brent
    • Nov 2008
    • 1214
    so the book says possible m14 (leading edge stopper motor) malfunction.
    does anyone have any experince with a c 1194? I know it is in the fs 527
    any thoughts? I have tried to turn off the main power and reset. just goes right back into this code.
    thanks
    brent
  • mo0651
    • 1054
    Re: bizhub c363 with a c1194
    some of these finishers have the shaft and holder on the shaft on the exit side of finisher. I think there is an update on tech site.
    • brent
      • Nov 2008
      • 1214
      I will search the tech bulletins. I have the finisher here at the shop with me now. hope to get this thing going today
      brent
      • brent
        • Nov 2008
        • 1214
        also. I goofed up. this is the fs 529. the small finisher that fits into the machine. in my original post I stated it was a finisher 527
        • brent
          • Nov 2008
          • 1214
          I thought I would try one last time to pick your brains. I did find some referances to bulletins. but they would not pull up. does anyone have the bulletin they could post on this issue. I am still lost.
          thanks
          brent
          • lanierboy
            • 149
            Hi Brent, did you ever resolve the issue with you FS-529?? i have one doing the same, any help would be great.
            • brent
              • Nov 2008
              • 1214
              I did not get it resolved. I ordered the parts and was not able to get the new sensor in or actuator in yet.
              I know where they go. but it is a pain.
              brent
              • lanierboy
                • 149
                brent
                I am taking it to the workshop on monday where we have a couple of spare ones, I will let you know what i find, working on this finisher is very painfull process
                • brent
                  • Nov 2008
                  • 1214
                  if you see the design of this sensor and actuator the new actuator is longer and actually hits the sensor easier. but the problem is getting the new actuator in its place. it is huge. there is a guy here that said he could do it blindfolded. but he would never return any of my pm /s I wish he could give us a hand
                  brent
                  • lanierboy
                    • 149
                    Hi,
                    I have now managed to fix my finisher, I found in the konica manual a reference to C1194 being caused by the SD3 solenoid blowing CP7 on the main board.
                    Upon checking the CP7 i found it was ok so i decided to check the solenoid assby, I found that the arm from the solenoid had become trapped on the wrong side and so could not move, also i found that the spring as detailed in the attachment had dis-appeared. fitted new spring and test ok.
                    I think this code can lead you astray from what is really wrong.
                      • 23010
                      Nice work!
                      In class, I was elected to install the new style motor assembly and the rest of the updates. We allocated 1 hour and it took closer to two hours to perform. They cram a lot of mechanics into that little finisher. My classmates cordially invited me to do any updates required on their FS-529 finishers.
                      I've been lucky so far. I haven't gotten any calls yet.
                      • brent
                        • Nov 2008
                        • 1214
                        I guess I am kind of confused now. while yes I have not fixed one in my shop. I was told that it was a sensor and an actuator problem. or am I thinking of another problem I had on a copier.. lol
                        brent
                        • brent
                          • Nov 2008
                          • 1214
                          yep I was confused. I had a problem with the small inner finisher as well. which is what this thread was about. I interjected with a comment about the larger finisher.
                          the small finisher seems to be a huge big pain as well
                          brent
                          • PeterG
                            • Jul 2008
                            • 177
                            We have forbidden our salesman to sell any more of these. They are "pricks" of things. Unfortunately for me, I have become the local expert for them. I end up doing all faults on them. They are virtually impossible to repair in the field. Fortunately, we have a "roving" spare finisher which we use as an exchange unit.
                            There are two little white "hangers" that lift up the exit roller. These dislodge & break regularly. Tiny bits of white plastic about the size of your fingernail. $75.00 a pop here in Australia. Absolute bullshit. Then their is the chronic broken lift mechanism. Absolutely everything about these finishers is a pain to replace.
                            I hate em, with a passion.
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              I have an intermittent 1194'ing fs-529 thats been thrashed within an inch of its life with stapled jobs.
                              the alignment paddles and stopper guides the code talks about dont even move freely anymore. Once the poor quality grease is contaminated with paper dust it turns into glue and binds everything up.
                              its impossible to fix in the field, and so far after 1 hour of disassembly and a million pieces everywhere I gave up. I think I'm going to toss it in the garbage..
                              Such a simple problem is a major pain in the ass to rectify.
                              ***edit
                              I persisted and got the alignment section out, it comes out as an assembly through the front once the tray and guide are removed and everything around it in the way is removed. Even the wiring is a pain in the ass to get out the way. What a nightmare! Its more for my own curiosity, i will never be doing this again.
                              This is now cleaned, lubed and moving as smooth as silk. This is a second generation fs-529 with all the upgrades including the update intake guide assy, its never given any troubles till now so i will give it another chance.
