920 gives J1701 on Tray3 only
  • mrwho
    Major Asshole!
    • 4299
    [Jamming] 920 gives J1701 on Tray3 only
    I've already been through the paces, and even went to the extent of testing the 3rd tray on another machine - runs perfectly there. I've done everything I could think of - too many things to remember and write here - but I'm open to any suggestions you might think of.
    Cheers!
    Mascan42
    Ibid
  • Albonline
    • Sep 2008
    • 1154
    Re: 920 gives J1701 on Tray3 only
    high count on the main body? if so try looking at the vertical conveyence rollers , is the od of them reduced?
    • mo0651
      • 1054
      The jam code is for paper conveyance..clutch 9 and 10. those part #'s are common failure. Does it jam when duplexing? Could be ADU drive board.
      • mrwho
        Major Asshole!
        • 4299
        Thank you both. As for the rollers, I'll order them just to be on the safe side. ABout the clutches, I swapped them all around between the trays and the vertical feed unit, and the two on the ADU between themselves, as well as a new one for testers, but the problem still remained. The machine will jam from tray 3 even when copying single sided face up, so I took the duplex unit and the reversal unit out of the equation.
        Mascan42
        Ibid
        • Albonline
          • Sep 2008
          • 1154
          to eliminate the rollers try some electrical tape . a couple layers in the direction of rotation will work as a temp measure.
          • hosman80
            • Jun 2008
            • 38
            i've had that issue twice, one was the ADU board and another one was two bad one way gears on the manual feed assy, they are also involved in the driving of the vertical conveyance section and they were slipping. part number 55VA 7718 1 qty 2. look into this. hope it helps.
            • mrwho
              Major Asshole!
              • 4299
              New ADU board, two new one-way clutches on the bypass driving system, sandpapered the shaft of those two one-ways, new vertical conveyance rollers - and still the problem persists. I'm lost. Help please!
              Mascan42
              Ibid
              • Spidula
                Konica Minolta Technician
                • 83
                Looked on Infohub for your 1701's.
                J17-01 (bizhub PRO 920) or J-1701 (bizhub PRO 950). The jam may also occur intermittently when duplexing.
                The manual feed drive gear is slipping on the manual feed drive shaft.For bizhub PRO 920: Replace the manual feed drive gear (p/n 55VA 7718 1, quantity=2) and the manual feed drive shaft (p/n 55VA 1536 1).
                Just noticed this has been mentioned already and Icant seem to delete it.
                Spid!
                • mrwho
                  Major Asshole!
                  • 4299
                  Swapped the motor driving the manual feed system with the one at the exit of the ADU, still no change. I'm looking at the machine right now like a cow looking at a combine harvester, trying to guess my next move. Thanks for all the input so far, and I'm still open to suggestions.
                  Mascan42
                  Ibid
