Konica Minolta bizhub c351 with fiery ic-402 - cable type?
  • thendral
    • Mar 2011
    • 82
    Hello All,
    I have a KM C351 with fiery. When I directly connect the copier byapssing fiery it works fine.
    The firey controller has one cable (SCSI type interface connector) but missing other cable (ethernet cable?).
    I tried to use the ethernet cable, but the copier is not recognizing the fiery.
    I am not sure what type of cable it is. I have a cable crimp I can make one, but not exactly sure what type it is. Is it a crossover cable?
    Checked the service manual no use. Any help here is very much appreciated.
    Thanks to all.
    Thendral
  • Albonline
    • Sep 2008
    • 1153
    Re: Konica Minolta bizhub c351 with fiery ic-402 - cable type?
    yes, crossover. when fiery is connected do you get the info icon on the screen? Are you setting the controler type correctly to use the fiery?
    • thendral
      • Mar 2011
      • 82
      Thank you Albonline for the reply. I will try with the crossover cable. How can I set up the controller type?
      • Albonline
        • Sep 2008
        • 1153
        download the ic 402 install manual from kmbs
