Bizhub Pro 920 - 950 carstock
  • blaze2000
    • Sep 2010
    • 232
    Hey folks, apparently MKM.com is not liking me today, and I can't log in. perhaps you guys could help me today. I need to create a initial car stock for our techs to carry as we acquired a handful of neglected Bizhub Pro 950's. If I could get into MKM.com I believe they have these lists but even with this, I would like some experienced techs add to the standard list of items they feel needed. Thanks guys, much love (rep) given to anyone with some good help as I need to compile this ASAP. Thanks Again
  • Albonline
    • Sep 2008
    • 1151
    Re: Bizhub Pro 920 - 950 carstock
    What I see mainly being used in our parts department are drums cleaner blades cro wires and whole cros both ts and charge. fuser upper rollers and bearings with lower rollers and heat sleeves used at a lower rate. feed rubber seems to be used at a pretty low rate. and of course developer and cleaning webs as often as pm kits. these units are tanks and stand up well to use as print reproducers, solids are not so great on these. good luck.
    • SmellsHot
      Head Tech
      • 512
      sounds like he nailed it!
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • blaze2000
        • Sep 2010
        • 232
        OK, thanks. Does the 500k pm kit have a web in it, or is that seperate? Thus far I have the following, anything missed? Thanks again
        500k pm kit
        cleaning blade
        rollers for adf
        developer
        drum
        upper and lower fuser rollers
        upper and lower fuser claws
        upper fuser bearings
        lower heat sleeves
        set of rollers of each paper drawer
        • Albonline
          • Sep 2008
          • 1151
          see attached file. pm kit packing list
          • minimerlin
            • 851
            500k pm kit
            cleaning blade
            rollers for adf
            developer
            drum
            lower heat sleeves
            The PM kit contains 2 cleaning blades, I have never had to change one outside of the PM!
            Please do not PM me without asking first.
            • Albonline
              • Sep 2008
              • 1151
              should be upper heat sleeves
