transfer belt did not reset
  • marlon29
    • May 2011
    • 51
    good day,
    has anyone encountered that the newly installed transfer belt unit did not reset? The fuse was broken upon installing the transfer belt but the life did not reset.. C253 model, we tried to replace the unit with a new one but the life did not reset also...
    any suggestions will do..
    thanks
    marlon
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: transfer belt did not reset
    Check for a blown ICP
    The gene pool could use a little chlorine.
    • marlon29
      • May 2011
      • 51
      we already replaced the board(prdb) because we found out that there is a blown icp(icp5) but still the problem is not corrected
      • Osty
        • Mar 2012
        • 4
        Are there any warning codes displayed during/after stabilization? Any P codes will prevent consumables from resetting.
        • emujo
          • Jun 2009
          • 3009
          Check for 24v at the board..and perform continuity check from board through x-belt, back to bord.if not present, the MFP will not see the new fuse...if you can't repair this the CQ will start to drift off..EMujo
          • sebastion
            • Feb 2012
            • 17
            I would guess what the last guy said m/c may be showing a p-code got the oil can symbel ?
            • blaze2000
              • Sep 2010
              • 232
              Try doing a trouble reset? Flash firmware? As EMujo stated, check for 24 volts and continuity.
              • Max Kilby
                • Oct 2011
                • 30
                Had a similar issue with the Fuser reset on a C203. No oil cans. Transfer belt reset OK with our one though. Tried various things including soldering a quick blow really tiny fuse in circuit and it didn't blow either.
                Ended up getting the 'new' firmware and reflashing the rom.
                There is a firmware version that will allow you to turn off notifications for IU, Fuser and TB - though I don't know what the effect would be if you have already expired the life of your transfer belt.
                MAX
                • marlon29
                  • May 2011
                  • 51
                  we have found out that the lock of the transfer belt was grounded to main body that's why the transfer belt did not reset..
                  thanks alot
