Network setting missing
  • bobe
    • Oct 2011
    • 38
    Hy,
    I have a bizhub C451. Network settings are missing in Admin setting and I can't ping it. I also tried to found the Mac address with arp-a but no succes. I reset in Service 1-Data Clear ( Network Reset) but nothing. Do i have to use Firmware Imaging Toolkit 2006 and reset the NIC setting.
    • 22995
    Re: Network setting missing
    I had a machine once that the network settings button would not appear. As an experiment I connected a live network cable, then powered up. To my delight the network settings button appeared, and worked normally. Who knows? I could be that easy. =^..^=
    • bobe
      • Oct 2011
      • 38
      should I try to connect direct to copier with my laptop.Do you think is the network isues? I reset the copier many times and I unplugged the network cable.
        • 22995
        Sure. That's a good idea. A lot of laptops do not require a crossover cable now, but mine does. Try it that way first. Of course you'll have to set a static address in the same range as the copier to your laptop. =^..^=
        • bobe
          • Oct 2011
          • 38
          I printed the Configuration page and I have the IP and Mac address, but the copier is not in the network. It's strange because anothers tabs are mising not just network settings but also One-Touch/User Box
            • 22995
            Here's another thought, tell me if this database entry sounds applicable:
            In this case several of the Utility/Counter buttons were missing. =^..^=
            • bobe
              • Oct 2011
              • 38
              I have the problem with Ricoh worst cables on DSm 520. About Konica I will try tommorow to connect direct with the network cable to the copier. I downloaded the firmware for NIC reset and I hope it's gonna work. Thanks
              • TheOwl
                • Nov 2008
                • 1732
                On Konica Minoltas that are plugged into the network, it does take some time for the Network Settings button to appear because the machines are set to DHCP out of the factory and the machines do wait some time before they class the DHCP attempt as failed.
                If you enter in a static IP address into the machine and then turn it off and on again without the network cable, you will then find that the Network Settings button appears a lot quicker.
                As for the One Touch/User Box, go into service mode and make sure that the HDD is set to Installed. If this doesn't help, then login into the Administrator Settings and get into the One Touch/User Box from there. Sometimes, depending on the method used, this button disappears from the standard menu when using authentication on the machine.
                • morpk
                  • Oct 2010
                  • 97
                  Hi Guys i get this all the time with Konica installs,
                  If the machine is set to DHCP it sends a ARP request to the DHCP server, if theydont talk the you need to wait for the ARP to time out then the Network settings button will appear after the ARP request fails then you can manually enter network settings, just check that you are getting lights on the copiers network card, also when first powering on the machine i can take a 1 minute or the network card to initialize.
                  • JR2ALTA
                    • Feb 2010
                    • 2030
                    Originally posted by bobe
                    Hy,
                    Konica's go braindead, it's just part of them sucking and all.
                    You have two options
                    One: call Konica, send in NVRAM, fill out paperwork, receive said NVRAM, fill out more paperwork, be on your way.
                    Two: try what knowledge base says and do an all clear but mind you your machine will go back to an assembly line state
                    • bobe
                      • Oct 2011
                      • 38
                      hey , we just fixed. We connect direct with the laptop to the copier and with arp-s found the IP.
