FS-528 on bizhub PRO 950
    • 23010
    OK, confessions first. I had it apart to check out PS19 for "Sub Tray full. Please empty tray." There wasn't anything obviously the matter, and thanks to a little FM that message disappeared. But I created the problem that followed.
    After re-assembly, the back cover of each stapled set was wrapped around the set and stapled through and the set did not eject completely. Apparently the set eject arm is on a timed belt/gear combination. I've never really examined one of these, and the manual doesn't offer anything, but I'll share what I discovered:
    When it's working properly the eject arm parks at the backside of the sub tray. The edge of the eject arm that pushes against the finished sets parks at the same level as the top edge of the horizontal support for the tray. When a stapled set is started the eject arm moves to the area below the staplers. When a set is finished, the set is ejected and it returns to the area below the staplers for the next set. When the last set clears, the eject arm parks.
    So this is how I timed it:
    After watching it jam up for a while I realized that the eject arm was parking 3" up the tray side of the sub tray. The simplest way to change the timing is to manually warp the big black gear enough to disengage the adjoining gear teeth, then rotate it ~1/2" at a time. At this point I wasn't exactly sure where the eject arm should park, but definitely not blocking the paper passage in the tray. Once I started getting closer, the staples started missing the paper, because the eject arm was waiting ~1/2" too high holding the paper above the staplers. If you take a flashlight and lay down parallel with the staplers you can see exactly where the eject arm waits. Just a few more gear teeth to jump, lowers the eject arm just below the stop between the staplers. It varies a little, but if you run 20 sets of 4 pages you can confirm that the eject arm is not quite touching the paper as it waits to be stapled and ejected.
    I have a theory that if one was to power cycle the machine, the black gear would home to the park position. Then a tech could warp that black gear (but not rotate it) and turn the adjoining gear until the eject arm comes up parallel with the support rib on the back of the tray. At that point it would be just a few gear teeth one way or the other to find the ideal timing.
    Does anybody know a better procedure to time one of these in the field? There do not appear to be any sort of timing marks on the gears. I won't be so stupid next time, and mark the gears. =^..^=
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: FS-528 on bizhub PRO 950
    Check field service manual for the 950 and look on pdf page 395 (adjustments section 11.4.4) and see if this is what you are talking about.
      • 23010
      I might not be looking in the right manual. There's not much about the finisher at all in the Field Service. I'll have to look for an FS-508 manual. =^..^=
      • Mr Spock
        • Aug 2006
        • 2064
        The latest on KM's website does not list options like previous manuals. The adjustments are there just have to expand all the sections till you find it.
        adjustment.pdf
          • 23010
          Maybe I'm glad I didn't find it. Having set the belt position by trial and error, this procedure makes no sense to me. The place they want you to look at the belt markings is inside a U-shaped bracket, and my X-ray vision isn't as good as it used to be.
          Thanks Mr. Spock. The next time I get in front of this machine I'll give it a shot. =^..^=
