KM C500 SRA3 Print Issue
  • eddieu
    • Apr 2011
    • 15
    [Misc] KM C500 SRA3 Print Issue
    Hello,I just bought a KM C500 copier and I'm trying to print a file on a sra3 media. I selected the type of the media in preferences as to be sra3 and in CorelDW I entered a custom layout (320x450).When I press print, my copier says to me To Load A4 paper, and if I select the bypass tray or any other tray I print's half of my image. Like it was zoomed on a corner.Can you help me please?
  • methogod
    • Dec 2008
    • 921
    Re: KM C500 SRA3 Print Issue
    try exporting to a pdf first. then try it again.
    you should be able to select the page size in the print driver. shouldn't have to make it a custom page.
    • serginho_vl
      • Sep 2007
      • 59
      For the info on how to print, see the user manual. You can find it with Google.
      From the user guide for C500:
      STD size: 13”x19”, 12”x18”, 11”x17”, 8.5”x14”, 8.5”x11”,
      8.5”x11”R, 5.5”x8.5”R, A3, B4, A4, B5, B5R
      STD (special):
      Detects A4R instead of 8.5”x11”R, A5R instead of
      5.5”x8.5”R.
      Non STD size:
      Max. 13” x 19.2” (330 mm x 487 mm) ~ Min. 5.51” x
      8.27” (140 mm x 210 mm)
      Wide size: 11”x17”W, 8.5”x11”W, 8.5”x11”RW,
      5.5”x8.5”RW, A3W, B4W, A4W, A4RW, B5W, B5RW
      • methogod
        • Dec 2008
        • 921
        should be ok as SRA3 is smaller then 12x18 (i know most of the top out at 18.25x12)
        unless the C500 is that much different.
        • serginho_vl
          • Sep 2007
          • 59
          Yeah, it should fit.
          The largest size I ever printed was A3wide (on office machines - not on production printers).
          The problem is to make the copier to recognize that size - either you use one of the sizes it knows (and SRA3 isn't one) or you make a custom size.
          Try and make a custom size from copier control panel.
