Bizhub 250 Admin code
  • LennoxD
    • Sep 2011
    • 82
    How can I reset the admin code to access the Utility counter. I need to clear the drum count after drum replacement
  • morpk
    • Oct 2010
    • 97
    Re: Bizhub 250 Admin code
    why do you need to reset the admin code normal code would be 12345678, or 00000000
    • LennoxD
      • Sep 2011
      • 82
      The customer mentioned that the last tech could not recall the admin code thats why I wanted to know how to reset thinking that i was probably some unsual number. Thanks
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        Normally it is 00000000 (8 zeros).
        I only want say that if you reset drum counter now that the new drum has worked, probably you'll run in a C2557 code...
        Better for you to set the bit 3 from 1 to 0 in 418 soft switch settings avoiding in this way the reminder to change the drum..
        ... In the minute that you're thinking of giving up, think about why you lasted so long ...
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • LennoxD
            • Sep 2011
            • 82
            to Acusso1234; If I was to make changes to the bit setting will I still get the error code C2557? Cause I changed drum, developer and reset counters and after a few hrs the C2557 error came back. One thing that I encountered was the F8 did not seem to work. I had expected the copier to do something besides just beep when I pressed the start button when F8 is on the display.
            • kingarthur
              • 1369
              when you went into F8...was the start button "blue" when you pressed it, if not you haven't done the set up....some of these are a nightmare...for example..i've had some that wont let me run F8 if the RADF is up...
              • LennoxD
                • Sep 2011
                • 82
                The start button was not blue. when i press the start button nothing happened.
                • kingarthur
                  • 1369
                  if the start button isn't blue...you cant run the F8...keep the side door open until you are ready to carry out the TCR, only close it when you are ready to press the start button in F8...have you reset the C2557 error..
                  • LennoxD
                    • Sep 2011
                    • 82
                    Got F8 to work kingarthur. Thanks very much.
