Please help me
  • Mourad
    • 18
    Please help me
    I have konica 7035
    the Problem f-35-4
    Please help me
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    this is a problem with the fuser (hot rollers). sometimes this will reset in the service mode or you may need parts first before it will reset. if you are not a tech you may need to call one for this or try and get a service manual to reset or further troubleshoot. good luck
    • Mourad
      • 18
      thank you
      thank you mr.
      but can you tel me haw to reset it
      • dogsbody
        • Jun 2007
        • 289
        Originally posted by Mourad
        thank you mr.
        This infomation is not something that a lot of people here will just give out because there is a safety issue involved. Most of the time the worst that will happen when reseting is a reoccurance of the code but nobody wants to be the one who tells how to reset and then has the building burn down because of a faulty fuser (IT HAS HAPPENED). It should be a tech who inspects the fuser then resets the code.
        In any case in my experience if one of these machines calls a temp code it is because a part is faulty, it will call the code again. This is more so if you are running the machine past over it's PM cycle of 100K.
        Spend a few dollars and call a tech.
        The force will be with you always.
        • Mourad
          • 18
          but in my country we have not any good technical services
          thank you Timmy
