C652 No drum reset
  • suomi
    • Oct 2008
    • 152
    C652 No drum reset
    2 New black drum unit tested & no reset drum counter!!!
  • JustManuals
    • Jan 2006
    • 9838
    Re: C652 No drum reset
    Paul@justmanuals.com
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Make sure the pins arent bent on the dv unit that contact the drum chip.
      Had this happen before when inexperienced tech replaced drum cart in a ham fisted manner
      • Gaffers01
        • May 2011
        • 334
        Check that there are no "P" codes up, as I think if there is the drum will not reset.
        • emujo
          • Jun 2009
          • 3009
          Most likely you have not followed the instructions properly...the front door must be open when you do the reset. Emujo
          • suomi
            • Oct 2008
            • 152
            yes if you change fusing unit or transfer belt. But NOT drum...
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Ahh, that proceedure is for the belt and fusing unit. The drum is provided with a "new article detection device"
              • stefanv
                • May 2010
                • 13
                Had same problem!!!! Check cn32 on PRCB for proper connection....
                • suomi
                  • Oct 2008
                  • 152
                  did not help but still running. B IU counter is over 11000...
