Develop 251 TN210K FIT IN A Konica C250 ?
  • Kenny
    • Jun 2009
    • 529
    Hi chaps
    anyone know the above ? Will save me a job if it does ?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Develop 251 TN210K FIT IN A Konica C250 ?
    doubt it, any consumable with an eeprom will only work in its designated machine identity code / region.
    • kingarthur
      • 1369
      not knowing how compatible the 2 m/c's are i couldn't say....however, we no longer order C250 toners or IUs, as we've discovered that C352 toners will work, just need to cut the lugs, and you can put in C352 IUs by changing the chip for a C250 chip...
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        that is quite surprising to hear - i never would of thought the toner would of been accepted without replacement of the chip.
        • Kenny
          • Jun 2009
          • 529
          TOP MAN thanks very much the toner worked (TN312K) in Develop +251 so would imagine it will work in a C250 KM machine
          Love this site thanks very much KingArthur
          • kingarthur
            • 1369
            you're welcome...we discovered it by mistake, when the customer fitted the toner from his C352 into his C250....we decided to let it run & see what happened, haven't bought any C250 supplies for over a year now
            • KM7155
              • Aug 2008
              • 146
              Hi Good day,
              can anyone confirm that the C250 toner can be use in C352 without changing the chips?
              I have C252 toners in stock, and would like to use it at the C352 machine.
              thanks in advance.
              • ck1
                • 485
                Originally posted by KM7155
                Hi Good day,
                thanks in advance.
                Yes work . only the cover problem
                • KM7155
                  • Aug 2008
                  • 146
                  Thanks ck1.
                  Btw, are u from my?
                  • ni311
                    • May 2008
                    • 658
                    Is this C352 toner cheaper or is it worth trying in an 'out of stock' situation?
                    Konica Minolta Error Codes - Explanations and Solutions
                    • ck1
                      • 485
                      Thanks ck1.
                      Btw, are u from my?
                      ya ! you also from MY ??
                      • KM7155
                        • Aug 2008
                        • 146
                        we have some TN312 toner in stock, and don have TN210 toner anymore.
                        is good we can use the TN312 in C252, because we have less C352 in the market.
                        • KM7155
                          • Aug 2008
                          • 146
                          yes, im from northern part, u are from southern part, right?
                          • ck1
                            • 485
                            Haha............. Yes . you are tech from KM ?
                            • KM7155
                              • Aug 2008
                              • 146
                              nope. are u attach to KM?
