KM Bizhub Fax and finisher problem
  • Gabriel
    • Jun 2006
    • 140
    KM Bizhub C352 Fax and finisher problem
    They can send faxes, but can't receive
    I got this message and error codes
    "Message deleted due to an error"
    R09
    R25
    R27
    Finisher is working fine when copying but
    when faxing the trays goes all the way up
    and trown a service code C1183.
    the guides for the trays are new and both
    trays activate the lift sensor when they move
    up or down.
    Any help is welcome
  • blaze2000
    • Sep 2010
    • 232
    Re: KM Bizhub Fax and finisher problem
    check to make sure the hard drive is installed and set (Tech Rep mode, under System 2, set the HDD to Installed.) that is most likely the fax error cause....
    Check your upper limit sensor, if its' good, check your firmware, this firmware can fix some timing issues. Firmware version 07 (9J08-F050-G00-07-000 CHECKSUM-6881 Finisher.EXE) is for the bizhub C300/C352/C352P.
    Please install bizhub C352/C352P Special Firmware version GWB-K0. This firmware resolves the issue of C-1183 when FS-514 is attached.
    • Gabriel
      • Jun 2006
      • 140
      blaze200
      Thanks for your fast response.
      Not sure if Hard drive is installed
      I'll check it tomorrow morning
      Best Regards
      Gabriel
      • RRodgers
        • Jun 2009
        • 1947
        When the fax doesn't work on a Konica the first thing I ALWAYS check is the marketing area in tech mode. I usually find that it was never set to US and is still in JP.
        • roberto.bertolani
          • Feb 2012
          • 19
          errors
          R09
          R25
          R27
          ECM signals are incorrect and I always disable the ECM mode technique submenu fax.
          c1183 error is caused by a sensor limit Tray got up and I recommend doing all of the 502 FW and also fax to the latest versions
          bye Roberto
          • Gabriel
            • Jun 2006
            • 140
            Thanks Guys
            Marketing area is US
            ECM is disable
            The machine doesn't have a hard drive,
            I'll install it and verify the firmware version
            Best Regards
            Gabriel
            • Gabriel
              • Jun 2006
              • 140
              Thanks Guys
              I installed the Hard drive and set to installed, that fixed the Fax issue.
              The finisher still not working. the upper limit sensor signal is fine,
              somebody willing to share the latest firmware for Bizhub C352?
              Regards
              Gabriel
