C552 c2554 Error
  • Mooseface2r
    • Jan 2011
    • 114
    C552 c2554 Error
    Has anyone got a heads up on this code C2554, in the manual it gives the below. the M toner was very low when it started throwing this code. i replaced the toner but still have the code.
    Any idea? i have ordered a M Imaing unit but im sure i must be missing something.
    1 Reinstall toner cartridge
    2 Reinstall imaging unit
    3 Change imaging unit
    4 PRCB ICP17 conduction check
    5 Change PRCB
    6 Change sub hopper unit
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: C552 c2554 Error
    Hi, you can try a Toner Supply. Have a look at the hopper too. How the magenta test looks like?
    Are the values in table number ok?
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • Mooseface2r
      • Jan 2011
      • 114
      HI, what table number are we talking about?
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        State confirmation-->Table Number in Service Mode
        • morpk
          • Oct 2010
          • 97
          i like to try the basics first
          trouble reset: turn off machine hold down utility/counter button (keep holding), turn on machine, when you see a black circle on the top right hand corner let go of the utility button hit the trouble reset button and then reset machine.
          hope this helps
          • kingarthur
            • 1391
            when i've had this problem on older (c250/ c352) models, it has always been either the toner supply motor, or the clutch inside the toner drive unit, on a C451 it was the toner sensor in the sub hopper, it's the same sensor as the "thunderbolt"....the one in the dv unit....
